high beam h4 conversion need help
Old Dec 25, 2010 | 09:18 PM
bcfipp's Avatar
I went to switch the sealed beams to the h4 unsealed beams. I noticed that the high beam connector is a 2 prong. The bulbs that I have are a 3 prong. Is there an adapter? I am lost. Any help would be great. Thanks
Old Dec 25, 2010 | 10:02 PM
Al Hasse's Avatar
Car: 1992 RS / 1989 RS
Engine: 3.1L MFI / Vortec 383 TBI
Transmission: T5 / LS-T56
Axle/Gears: 3.42 open / 3.73 Eaton posi
Re: high beam h4 conversion need help
Find an H7 bulb and you should be fine. H4 is a HI/LO beam bulb and has 2 filaments and 3 connectors (one for each filament and ground), H7 is a single filament bulb with 2 connectors. Use the H4 bulbs for the outer headlight pair and H7 for the inner pair.
Old Dec 26, 2010 | 08:16 PM
bcfipp's Avatar
Thanks for the information. I was looking up h7 bulbs and they are not cheap.
Old Dec 27, 2010 | 12:59 AM
Al Hasse's Avatar
If you haven't done so already, you'll want to upgrade your headlight wiring harness to handle the extra current. There's a nice kit in the following link that sets you up for a pair of H4 lights and a pair of H1 (instead of H7).
Use the kit # HL28202 (straight ground)
http://www.rallylights.com/detail.aspx?ID=1247
oil pan 4
Fabrication
Oct 6, 2015 11:56 AM
bryanwood74
Sep 24, 2015 09:50 PM
KRUSS
Aftermarket Product Review
Sep 5, 2002 02:21 AM
IROCKER
Feb 21, 2002 02:27 PM
Synergy
May 29, 2001 04:51 AM
