Need Trunk Release in 91 Bird
Old Jan 30, 2011 | 07:03 AM
luvofjah's Avatar
Car: 91 Black Formula KR
Engine: 305 TPI R69/G92
Ok... so I have a trunk Pull Down in the car...
And this one with a trunk release, I have too...
Different mounting points, etc... I don't care for the trunk pull down, I just want the trunk release... I can see that the stock one has a remote wire going to it, from key turning to latch, but no power assist...
Has anyone adapted a "trunk release" to these? I think these may be for ones that have a cable...??? In a way, it does have a cable... Eventually, I'm gonna have a blackout, so rear key access will be covered too... Here is a DEI trunk release solenoid...
http://viper.com/P-522T/Trunk-Release-Solenoid
Thanks!
Old Jan 30, 2011 | 10:13 AM
Pocket's Avatar
Car: 91 Trans Am
Re: Need Trunk Release in 91 Bird
Pop the cable off the trunk lock cyl and fab a simple bracket to hold the 91- release solenoid to it
I wouldnt suggest dumping the 92 pull down assembly (tan) its significantly stronger than the older versions
Old Jan 30, 2011 | 11:55 AM
luvofjah's Avatar
Dump the stronger tan one?
I thought the tan one was late 91 and 92...
The all silver is earlier, with the trunk pop.... From the looks of it, the trunk pop looks like it sits on the latch gear.. I need to remove it to see for sure....
Old Jan 30, 2011 | 02:42 PM
Pocket's Avatar
Car: 91 Trans Am
Keep the tan one. Modify a simple bracket to use the popper off the silver pull down
jrdturbo
Mar 31, 2016 02:58 PM
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
87v6Bird
Brakes
Oct 4, 2015 07:37 AM
