HELP...FOG lights
Old Feb 2, 2011 | 05:20 PM
medhawk020's Avatar
Car: 1990 Camaro RS (SS CLONE)
Engine: 350 cid bored .30 over
Transmission: 700r4 B&M shift kit
Axle/Gears: stock Axle 3.73 gears posi
HELP...FOG lights
I got the Factory fog lights installed on my Camao RS and I cant find where the relay goes to?? I got the wire harness for TPI Parts on E-bay. So any help I can get I would Like very much
Old Feb 2, 2011 | 07:16 PM
camaronewbie's Avatar
Car: 1992 RS
Engine: Carbed 350
Axle/Gears: 3.42 posi
Re: HELP...FOG lights
What they are having you do (I think) is run a relay so you're not running high amperage juice in/out of the cabin to the switch. The switch wires need to come out to a relay under the hood to activate the relay, then a power wire is run directly from battery to the relay, and out to the foglights.
So - when you turn on the switch, a low amperage 12v+ is sent out to the relay activating it, when the relay is activated, it makes a connection inside of it between the wire to the battery and the fog lights, so the foglights are getting 12v+ directly from the battery.
The relay should have 4 prongs, one is 12v+ from the switch, one is ground, one is 12v+ from battery, last is 12v+ out to foglights.
TrevinE
Sep 14, 2015 03:20 PM
florida_gators
Exterior Parts Wanted
Sep 7, 2015 07:19 PM
flash2042
Interior Parts Wanted
Sep 7, 2015 07:15 PM
luvofjah
Sep 3, 2015 07:08 PM
