smog stuff
Old Mar 26, 2011 | 03:39 PM
hartsmike's Avatar
Car: 1986 Black IROC
Engine: 305 Quadrajet
Transmission: 5 speed
Axle/Gears: 273
smog stuff
The owner before me took the smog off the IROC including the cat.. It's a quadrajet.. Now the check engine stays on and that aggravates me to no end. Can the computer be programmed to disregard anything smog related? Thanks
Old Mar 26, 2011 | 08:06 PM
camaronewbie's Avatar
Car: 1992 RS
Engine: Carbed 350
Axle/Gears: 3.42 posi
Re: smog stuff
Did they take the O2 out, or is it still there? You'll need the O2 sensor for the car to run decent.
Maybe it's just the EGR the ECM is missing, because there's nothing with the smog pump or AIR that will set a code.
You need to grab a paperclip, pull the codes and tell us what they are.
Old Mar 27, 2011 | 01:43 PM
hartsmike's Avatar
Axle/Gears: 273
Re: smog stuff
I asked and he said he cut the cat so im guessing the wire is gone too. how much truble wud it b to put the sensor wire back in? can the computer b set to not acknowledge its gone?
LT1Formula
Oct 8, 2015 08:34 PM
jaridjohn
Oct 5, 2015 07:01 AM
