No power to interior
Old May 18, 2011 | 08:48 PM
acadburn's Avatar
Car: 1989 Camaro RS
Engine: 305 V8
So i started with a simple starter swap the one was going dead by clicking and not wanting to start from time to time
Next i put in the 2nd starter hooked up the battery say 30 seconds later the starter tried starting by itself and burnt up b4 i could get it disconnected
returned to auto-parts store replaced starter re hooked up New new starter and now i have no power to the cab
However I tore out the 3 fusible links and replaced them with new fuses (did not solve the problem) there is power going in to the fuses from the starter
After disconnecting the battery i did have interior power once until i turned the key at that point the whole care interior died (i did hear a click)
Any ideas Should i burn my car????? any help would be greatly appreciated guys being this is my daily driver and I have been stuck at home for 2 days now!!!!
Old May 18, 2011 | 08:51 PM
camaronewbie's Avatar
Car: 1992 RS
Engine: Carbed 350
Axle/Gears: 3.42 posi
Re: No power to interior
All wires connect with the pos batt cable to larger terminal, only the purple wire connects by itself on the smaller terminal.
Old May 18, 2011 | 09:45 PM
acadburn's Avatar
Car: 1989 Camaro RS
Engine: 305 V8
Yes all the wires were connected to the pos batt terminal wire except for the purplish wire which is connected to the S (90%) sure on the purple wire without looking
BRoss99
Aug 10, 2025 05:08 PM
1992 Trans Am
May 10, 2023 07:19 PM
Vintageracer
Jan 10, 2020 05:33 PM
diana227vegas
Jul 8, 2016 12:27 AM
IrocBuzz
Camaros Wanted
Nov 20, 2015 11:29 AM
