Distributor Help
Car: 88 RS Camaro,70 chevelle,92 Geo
Engine: 305 TBI
Transmission: 5 Speed Manual
Distributor Help
Well when i bought my car the motor wasnt in the car, so i am putting it back together, heres the distributor, i need help with general info on it and whats missing, im sure it needs a cap and cables XD but i dont know if i still need the rotor
Car: 92 Camaro RS
Engine: LO3
Axle/Gears: stock
Re: Distributor Help
Wow, that looks pretty rusty, but not a problem as long as it still turns freely. Rotor goes right on top of the shaft in that slot and then the cap covers it all. Before actual use you may want to make sure it still has some heat sink compound or dielectric grease under the ignition module
Engine: 305 TBI
ok, the part that is really rusty, whats it called? also, should i buy the parts online like ebay or should i go to autozone?
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
The rusted part is the reluctor. It's just a dumb piece of ferrous metal, doesn't matter how rusty it is on the outside as long as it turns freely.
Engine: 305 TBI
ohh ok then ill just leave it, and about where to buy the rotor and cap, where should i get it?
Engine: 305 TBI
Engine: 305 TBI
even if it says EFI? sorry its just that i dont want to get the wrong one and im clueless
Engine: 305 TBI
ok thanks, ill order it right up and but the cables to, ill post a pics when i get it all in
RedLeader289
May 28, 2019 01:47 PM
HoosierinWA
Oct 7, 2015 10:15 AM
Damon
Sep 26, 2015 04:29 PM
