Heater settings....
Old Jun 4, 2011 | 05:30 PM
fasteddi's Avatar
Car: 1991 Camaro RS
Engine: Lq4 6.0 SBE s485 turbo E85
Transmission: Fsi th400 stage 4. TSI 5500 st
Axle/Gears: Strange S60 4:10s
Heater settings....
Im only posting this because i have had no luck on finding info on the search....My heater only turns on when its on high... this just started happening the other day... its either off on on high.... any ideas what the problem is???? Like i said the heater only works on the high position.....mabey the switch is bad????
Old Jun 4, 2011 | 05:42 PM
project89's Avatar
Re: Heater settings....
more then likley the resitor went bad in the heater box. but it could be the switch as well
Old Jun 4, 2011 | 09:00 PM
fasteddi's Avatar
Car: 1991 Camaro RS
I recently removed my messued up air cond. system... would that cause this prob??? Ill look at the heater box and check the ohm on the resistors then the switch....
Old Jun 5, 2011 | 06:51 AM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
High speed = relay
Low speed = resistors
JamesC
Old Jun 5, 2011 | 09:07 PM
whitedevilTA's Avatar
Car: 1986 Trans am
Engine: 5.3 LM7
Transmission: T56 6 speed
Axle/Gears: Dana 44 w/ 3.55's
It's most likely the resisitor. It mounts on the side of the AC box with 2 small hex bolts and when removed looks like a couple springs underneath. Replace that and you should be good. Take it out and check if any of the springs are broken or burned.
Formula8r89
Sep 22, 2015 04:24 PM
BWilcox
Sep 20, 2015 12:19 PM
