need advice asap
Old Jun 19, 2011 | 11:31 AM
Jeepnhal's Avatar
Car: 84 Trans Am L69
Axle/Gears: 10 bolt 3.23
need advice asap
my cars stuck halfway in road and wont start
1984 Trans Am
went to pull out of garage this morning and realized none of the guages were working,not even my aftermarket tach or temp guage
then i shut it off,bad idea
now i turn key no starter clicking,no relays clicking,nadda,i did bang on starter and i belive that helped it start one last time,still had no gauges,and then yup i shut it off
now its stuck in the road
battery is fine
grounds and cables seem fine
no loose wires to battery and starter
im thinking its the starter,any ideas?
Old Jun 19, 2011 | 11:35 AM
ASE doc's Avatar
Car: 87 IROC Z28
Engine: 355 cid TPI
Transmission: Custom Built 700R4 w/3,500 stall
Axle/Gears: QP fab 9" 3.70 Truetrac
Re: need advice asap
Start by checking the fuse links either at the starter, on the same post with the battery cable, or at a junction block by the battery on the radiator support. They are probaby loose.
Old Jun 19, 2011 | 01:22 PM
Jeepnhal's Avatar
solved..the p.o had jumped the neutral safety switch and i must have kicked it loose gettin in this morning.
however,still having problems.
guage fuse keeps blowing
dash illum fuse socket has no power to it
acc ports in fuse block have no power to them
everything was fine last nite,oh and this morn i put parking lights on and bell was chiming warning me they were on eventhough car was running and doors were shut
i pulled headlight switch incase it was bad but still blowing guage fuse
Old Jun 19, 2011 | 02:58 PM
ASE doc's Avatar
Car: 87 IROC Z28
Engine: 355 cid TPI
You need to check for power at both red wires to the ignition switch. One powers the ACC portion of the switch. The other powers the ignition portion. Sounds like the ACC side is not getting power. As far as the gauges fuse goes, you need to find the overload.
HoosierinWA
Oct 7, 2015 10:15 AM
jaridjohn
Oct 5, 2015 07:01 AM
gord327
Sep 29, 2015 10:18 PM
IROC ZELLER
Sep 29, 2015 03:00 PM
92projectcamaro
Sep 24, 2015 08:09 AM
