headlight troubles
Old Jul 21, 2011 | 09:53 PM
cypris09's Avatar
Car: 87 Gta
Engine: 5.3
Transmission: 4l60e
headlight troubles
I have an 87 gta and of course the headlights won't come up. Had the motors checked out and they're not the problem. So anyone have some ideas?
Old Jul 22, 2011 | 08:09 AM
cypris09's Avatar
Car: 87 Gta
Engine: 5.3
Transmission: 4l60e
Re: headlight troubles
Oh and BTW the motors when turned by hand do work so should I re wire them?
Old Jul 22, 2011 | 08:40 AM
BlackenedBird's Avatar
Car: GTA
Axle/Gears: Aussie 9-bolt/3.27 posi
You say you had the motors checked out. Checked out electrically? Will they go up/down by bypassing the dash switch? If so, maybe you just have a bad dash switch?
Old Jul 22, 2011 | 05:10 PM
cypris09's Avatar
Car: 87 Gta
Engine: 5.3
Transmission: 4l60e
Yes I took them to somebody who rebuilds electric motors said they where great. So I would assume wiring. How would I go about by passing the switch, I mean everything else turns on just the headlights won't come up
Old Jul 22, 2011 | 05:38 PM
Car: GTA
To test the switch you would need to pull it out & see if power is going in & going out when it is supposed to.
And check the relay before you go through the hassle of pulling the switch. I should have suggested checking it first place. On the firewall in a 87, it is a dual relay. 1 box, 2 sets of inputs & outputs, so that if 1 side fails? One headlight still functions correctly.
It is just to the left of the brake booster & fairly commonly fails. Open the hood, turn the lights on & if the headlights down come up? Tap on the box. Not HIT, but a few firm taps.
You can buy a rebuilt one here:
http://www.top-downsolutions.com/hea...ird-p-119.html or find you a used one somewhere. Junkyard maybe? I have a spare but keep it in reserve for this exact reason!
Old Jul 23, 2011 | 12:06 AM
lonsal's Avatar
Axle/Gears: 3.45, 3.27, 3.27
http://www.top-downsolutions.com/hea...pair-p-35.html
http://www.top-downsolutions.com/del...pair-p-87.html
Either of these headlight repair kits I make will solve the problem. What fails the first time on these 86-92 headlight motors is the bushings inside the gear. The bushings transfer the load from the gear to the 3-lobe hub that is staked onto the shaft that raises and lowers the headlight bucket.
Lon Salgren
Old Jul 23, 2011 | 12:17 AM
Car: GTA
Lon Salgren
Ummm....If the **** will still raise & lower them manually, doesn't that point towards an electrical problem? Doesn't those kits you listed only apply to lift motors that fail to work even manually?
Old Jul 23, 2011 | 12:01 PM
cypris09's Avatar
Car: 87 Gta
Engine: 5.3
Transmission: 4l60e
I will have to agree, that would be why I posted in electrical but I will for sure check on that as soon as I get motor back in and power to everything
Old Jul 23, 2011 | 12:02 PM
cypris09's Avatar
Car: 87 Gta
Engine: 5.3
Transmission: 4l60e
Oh, and thank you very much
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
J. Chris Davis
Interior Parts Wanted
Sep 28, 2015 11:55 AM
