Finally have a working fuel indicator,installed sender & pump
Old Jul 23, 2011 | 03:41 PM
mrrman's Avatar
I just removed the fuel sender and pump from my 87 TA. I didnt drop the tank, there was a butchered access panel in place so I took advantage if that. I am going to get a proper plate made to cover this area up. Immediately after installing everything, started the car up and it dropped to 1/2 a tank where it should be. One issue down, more to go.
Old Jul 23, 2011 | 05:34 PM
travis401's Avatar
Car: 91 Camaro RS
Engine: empty bay (for now)
Transmission: Built T-56
Axle/Gears: 3.42 stock posi disc
Re: Finally have a working fuel indicator,installed sender & pump
were the hard lines spliced together with rubber hose and hose clamps? if so youll wanna fix that.
Old Jul 24, 2011 | 10:12 AM
mrrman's Avatar
why??? it works and Ive seen alot of other people do it with great results. I will be leaving mine the way it is.
Frozer!!!
Jan 19, 2024 04:55 PM
RazorN8
Jan 7, 2022 11:44 AM
NBrehm
Aug 25, 2015 11:49 PM
justin57
Aug 20, 2015 07:05 PM
kyleb24
Aug 15, 2015 08:24 AM
