Help! need actuator headlight diagram
Old Jul 24, 2011 | 04:31 PM
1986Firebird350's Avatar
Car: 1986 Firebird
Engine: 350 SB Chevy
Transmission: TH350
I have attempted to fix my headlights not popping up problem before but failed to find the proper relays and switches etc. What I would like is to have an entire wiring diagram of the entire system from the dashlight switch right to the motors. I know there are 3 relays in the system and I will need part numbers off of them because they are no longer in the car. I know my motors work because I can hand crank them as well as hotwire them to come up and down. If worst comes to worse, has anybody done a rig that will work for these motors that works without the relays? thanks in advance and any help appreciated.
Old Jul 24, 2011 | 10:57 PM
vetteoz's Avatar
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
Re: Help! need actuator headlight diagram
http://www.austinthirdgen.org/mkport...ody_wiring.gif
The relays are there for a purpose so you don't have the heavy amps needed for the motors running all the way inside to the switch and then back out to lights.
Relays allow a little switch to switch big currents which is why they are there in the 1st place.
SavingPvtEric
Sep 29, 2015 05:59 PM
J. Chris Davis
Interior Parts Wanted
Sep 28, 2015 11:55 AM
