Battery hub thing question
Old Aug 8, 2011 | 10:51 PM
jb3829's Avatar
Car: 1991 RS
Engine: 383 stroker
Axle/Gears: 3.23 posi
anyone know how many accessories can be added to the hub located next to the battery? The stock stuff is all there but I want to add a fog light and a door popper lead to it but I want to make sure it's not gonna melt or something.....thanks
Old Aug 9, 2011 | 10:54 AM
1ADan's Avatar
Car: 1987 Trans Am
Engine: LQ9/L92
Re: Battery hub thing question
if you're looking to add a couple more circuits, I'd recommend getting an adapter for the battery terminal instead. It screws into the battery like to OE one did, but also has a stud coming off of it allowing you to hook up ring terminals to it. Can be found at most auto part stores or car audio shops for $5-20 (depending on bling factor)
Old Aug 9, 2011 | 11:46 AM
Maverick H1L's Avatar
Car: 2003 Hyundai Tiburon GT
Engine: 2.7L V6
Transmission: 6-speed
Axle/Gears: 4.41
You can also find other junction blocks (which is what the "hub thing" is called)...
Old Aug 9, 2011 | 08:01 PM
camaronewbie's Avatar
Car: 1992 RS
Engine: Carbed 350
Axle/Gears: 3.42 posi
Shouldn't have any issues connecting anything to the distribution block (except maybe an amp) - nothing else draws enough juice to matter I wouldn't think. I've got several things (including fogs) connected there for convenience (since I have my amp connected to battery terminal). Go for it!
Old Aug 9, 2011 | 08:49 PM
jb3829's Avatar
Car: 1991 RS
Engine: 383 stroker
thanks all.....I'll clean up the OE one and use that
Frozer!!!
Jan 19, 2024 04:55 PM
midge54
Dec 27, 2019 04:14 PM
justin57
Aug 20, 2015 07:05 PM
Bob88GTA
Aug 18, 2015 03:31 PM
redmaroz
Aug 16, 2015 11:40 PM
