Made some progress
Old Aug 27, 2011 | 08:48 AM
valicswarrior's Avatar
Car: 1985 Firebird S/E
Engine: SBC 350, mild cam Vortec heads
Transmission: Rebuilt 700R4 vette servo+shift kit
Made some progress
So I have had charging issues and have been working to figure out why. Today i pulled my relays for my cooling fans and presto my voltage was good. looking for opinions on the easiest fix here should i track down the issue or install an aftermarket cooling system?
Old Aug 28, 2011 | 02:16 PM
Pocket's Avatar
Car: 91 Trans Am
Re: Made some progress
Have your battery/alt tested. Fans draw alot of power, dual fans are generally 1/4-1/3 the total draw of a cars electrical system. Add in a stereo upgrade and the charging system isnt enough
If the alt and battery are fine, do a resistance test on the relays and fan wiring. A short can cause excess draw, also failing fan motors draw more and more current until they finally seize
Old Aug 28, 2011 | 02:22 PM
well one fan is brand new and this follows over from an old post this is the 3rd new alt and 2nd new battery only issue i am trying to figure out now i put the fans back to factory wiring and my primary turns on as soon as i turn the key and the secondary doesn't go on at all secondary being the brand new one it appears there are 2 problems i need to figure out
Old Aug 28, 2011 | 02:31 PM
Pocket's Avatar
Car: 91 Trans Am
Primary coming on with IGN suggests its been modified for the ECM/thermal switch to be permanently grounded. Unplug the thermal switch between the #6&#8 primaries and see if this stops. If it does, replace the switch, if not find where the wires are shorted/spliced to ground
Secondary fan doesnt come on until the AC is engaged. Your car will have to be running to test that because there is a redundant pressure switch for that
Old Aug 29, 2011 | 12:43 AM
but what if i didn't use my ac then my car would over heat with the one fan as of right now there's no belt on my a/c compressor because the compressor clutch is messed up
morrow
Members Camaros
196
Jan 13, 2024 12:21 PM
F.I. 57 Belair
Aug 23, 2021 01:09 AM
gixxer92
May 18, 2017 11:20 AM
SS-EXPRESS
Sep 28, 2015 09:14 AM
F-body-fan
Sep 17, 2015 12:16 PM
