Fuel Pump Wire Harness Continuity Test?
Old Aug 27, 2011 | 07:08 PM
Rich92 RS's Avatar
Car: 86 IROC-Z, 98 Z28
Engine: 370 LSx, LS1
Transmission: T56's
Axle/Gears: 3.73, 3.42
In the middle of replacing the fuel pump, and were wondering if we should reuse the fuel pump wiring harness? Tested the continuity of both harnesses, and came out with a constant reading of .3 on the ohm setting 200.
First pic is of the harness coming off the fuel pump, and fuel level sender.
Second pic is of the tank harness that leads/connects to the body harness.
Old Aug 28, 2011 | 02:13 PM
Pocket's Avatar
Car: 91 Trans Am
Re: Fuel Pump Wire Harness Continuity Test?
Use the lowest resistance setting on your meter for testing how good a connection is. .3 ohms is fine though. If the connector is brittle and cracking, replace it, otherwise rock it
Old Aug 28, 2011 | 07:17 PM
Rich92 RS's Avatar
Transmission: T56's
Thanks man. Got everything buttoned back up a couple hrs ago. So far so good.
92camaroJoe
Jul 29, 2023 07:57 PM
RazorN8
Jan 7, 2022 11:44 AM
Jae992
Aug 27, 2015 09:07 AM
justin57
Aug 20, 2015 07:05 PM
92camaroJoe
Aug 13, 2015 06:07 AM
