Do i have everything i need?
Old Aug 30, 2011 | 01:43 AM
ryanryan's Avatar
Im installing pw pl and pm into my non power anything car. I got 2 doors with all the wires cut coming off them and everything thats in the door. I grabbed the wiring harness that runs from the center counsle with the window switches to the kick panel and plugs into the plug in above the kick panel, i also grabbed the wires that go from the pass side door across the dash to he the drivers door (loose wires that i just pulled out) i also have the lock relay that is attached to the harness. its a 91 firebird the wires came from 91 firebird, we tried installing and can only get the windows to work and the power door locks on the pass side to work. tried everything cant get the mirrors or drivers door locks to work from the drivers side. i was reading on some post about having to take the dash off cause of some wires that run under there to kick panel or if those are the ones i pulled from the pass side that are connected to the drivers side. am i missing wires or anything relays? nothing needs to be hooked to the fuse box right thats what that plug does that the harness connects to? any help would be great what are we doing wrong? what do we need to do what am i missing im so confused.....
Old Sep 7, 2011 | 04:01 PM
NINÅ's Avatar
Engine: ► 400 KUBES ◄
Transmission: 765R4
Axle/Gears: EATON POSI 4.56
Mirror, Mirror On The Car . . . . . . . . .
The left power mirror and lock circuitry use the same connector located near the top and 80% towards the front of the left door.
Check for bad connections at that connector.
Happy Racing!
Make Noise, Turn Left, Repeat
