lights
Old Sep 6, 2011 | 03:34 PM
mcgee44's Avatar
Car: 86 camaro z28
Engine: 403 olds
Axle/Gears: posi 3.73
lights
my regular lights are super low and my high beams are fine but only one works,....but i noticed when i jam on the gas(showing off ) the low beams are no longer dim and they work fine...could this be a possible short and if so where??..and i also wanted to know if there was a fuse for the fog lights and where is the location..and i heard of adjusting the high beam switch but i cant find the location!!
Old Sep 6, 2011 | 05:24 PM
travis401's Avatar
Car: 91 Camaro RS
Engine: empty bay (for now)
Transmission: Built T-56
Axle/Gears: 3.42 stock posi disc
Re: lights
might wanna check the grounds for the lights. theres should be a ground on each side. i know the lights will do some funky things without both grounds being hooked up.
Old Sep 6, 2011 | 06:50 PM
camaronewbie's Avatar
Car: 1992 RS
Engine: Carbed 350
Axle/Gears: 3.42 posi
Re: lights
I'd also have a battery and alternator test done for free at just about any parts store - they test them in the car.
You issue has nothing to do with the high/low beam switch - if they change from low to high and back, leave the switch alone. The one high beam light that's out, simply needs replaced
Old Sep 6, 2011 | 07:43 PM
mcgee44's Avatar
Car: 86 camaro z28
Engine: 403 olds
Re: lights
alright thanks ill check it out tomorrow and give you all a reply
TrevinE
Sep 14, 2015 03:20 PM
florida_gators
Exterior Parts Wanted
Sep 7, 2015 07:19 PM
flash2042
Interior Parts Wanted
Sep 7, 2015 07:15 PM
luvofjah
Sep 3, 2015 07:08 PM
