factory guages...how accurate and reliable?
Old Sep 28, 2011 | 04:16 PM
Igorealfast's Avatar
Car: 1988 Gta
Engine: 383
Axle/Gears: Stock
Okay, going to fire up my new 383 this week. My factory guages are hooked up, but just how reliable and accurate are they. I have a set of mechanical guages I can install just to be safe, thoughts?
Old Sep 28, 2011 | 04:28 PM
87WS6's Avatar
Car: 1992 Formula Firebird
Engine: 305CID (LB9)
Transmission: World Class T5
Axle/Gears: 10-bolt, 4.10 gears
Re: factory guages...how accurate and reliable?
Assuming the speedometer is setup for the correct gear ratio in the rear end, they are accurate enough for general driving purposes.
Old Sep 28, 2011 | 05:56 PM
Car: 1988 Gta
Engine: 383
Axle/Gears: Stock
I was thinking more along the lines of oil pressure and coolant temp.
Old Sep 28, 2011 | 06:13 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
The gauges themselves are fairly reliable, usually it's the senders that need replacing. They might not be the most accurate, but they'll show you the trends that you need to recognize just fine.
armybyrd
Sep 28, 2023 12:16 AM
FormulasOnly
Jul 23, 2018 08:47 AM
IROCTheHouse
Exterior Parts Wanted
Oct 26, 2015 02:35 PM
ULTM8Z
Oct 2, 2015 01:25 PM
SS-EXPRESS
Sep 28, 2015 09:14 AM
