Ground wire keeps frying.
Old Oct 5, 2011 | 01:06 PM
fissionfusion's Avatar
Car: 1985 Pontiac Trans Am
Engine: Chevy 350
Axle/Gears: GM 10 Bolt
So yesterday, went to start my car after some relatively hard driving and *boom*, no start and smoke. So I replaced the battery and all the cables.
Start my car easily and it drives fine. Give it a little bit of gas and then *boom*, smoke. Pull over into a parking lot and see the ground wire from the neg burnt to a crisp. No damage elsewhere else.
I'm running a 350 pulled from a 74 police interceptor. Currently have an Optima Red Top battery (brand new) with the positive terminal going to the starter and the 10 gauge going to the back of the alternator. My negative terminal goes to the front of the alt via a bolt and to the 10 gauge to the chassis. Did I mess something up?
Old Oct 5, 2011 | 08:00 PM
Pocket's Avatar
Car: 91 Trans Am
Re: Ground wire keeps frying.
Second melted ground thread ive seen today
Remove the ground ring on the alt bracket, clean it very well with a wire brush or something abrasive so its back to being bare copper/steel. Next find an unused bolt hole near the alt on the BLOCK. Again clean it profusely until its bare iron
Reinstall and see if the problem persists. You dont have to wait until its smoking, just have a friend touch the cable to see if it gets hot
Also, you need to add a ground strap from the engine to the chassis
Old Dec 1, 2011 | 02:28 AM
Zeeboinc's Avatar
Car: '89 Iroc Z
Engine: Paxton SN-92 305
Transmission: 5 spd
I had the same flipping prob this afternoon only minor diff (305). I saw red smoke from under the hood and was like wow thats an absolute first. It was the insulating rubber burning off the wire. Deff gonna try to ground it to the block. Thnx.
Glowsock
Jul 24, 2025 03:15 PM
eightsixseven
Dec 16, 2024 01:50 PM
Jae992
Aug 27, 2015 09:07 AM
Glowsock
Aug 26, 2015 12:28 AM
Armored91Camaro
Aug 25, 2015 12:01 PM
