Autometer Pro Comp Ultra Light Air/Fuel Gauge Questions
Old Oct 11, 2011 | 12:50 AM
Verhagen82's Avatar
Car: 82 Firebird
Engine: Boosted LSX
Transmission: Built 4L60E
Axle/Gears: 4th Gen 3.42s
I just bought an Autometer ProComp Ultralight air/fuel gauge 4375. I was wondering if there was a way to wire it up on my 82 Firebird. I have no o2 sensors the way it is but I have a bung on each collector of my headers. I have no computer either, just strictly carb.
The gauge has three wires coming out of it; one red (power), one black (ground), and one purple (signal). I work at an autoparts store and have access to the full range of o2 sensors but what do I need?! We carry mostly Bosch o2 sensors.
I also read while doing some searching that you can wire the single gauge to a switch to get readings from each side of your motor; left or right.
Old Oct 11, 2011 | 12:52 AM
Verhagen82's Avatar
Car: 82 Firebird
Engine: Boosted LSX
Re: Autometer Pro Comp Ultra Light Air/Fuel Gauge Questions
This is the gauge:
http://www.autometer.com/cat_gaugede...id=3083&sid=11
And I realize that this is the o2 sensor kit they recommend:
http://www.autometer.com/cat_accesso...l.aspx?vid=162
**I have the bungs already on my headers and I have the wiring that comes with the kit as well; just no sensor.
Old Oct 12, 2011 | 12:12 AM
Zerocyde's Avatar
Car: 88 Camaro
Engine: 416 Stroker LS
Transmission: Magnum F
Axle/Gears: 4.11
What's a bung? A hole for a sensor to go in?
Old Oct 12, 2011 | 12:33 AM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Any single wire O2 sensor will work.
There isn't much point to putting a sensor in each bank, just pick one.
Then again, a narrowband sensor isn't all that useful in the first place.
Old Oct 12, 2011 | 08:09 AM
Verhagen82's Avatar
Car: 82 Firebird
Engine: Boosted LSX
when you say single wire you mean single signal wire o2? all should have a positive and a ground correct?
Old Oct 12, 2011 | 10:21 AM
mr305's Avatar
Car: 91' RS
Engine: 310 C.I.D. + n2o
Axle/Gears: built 10 bolt 3.73's
No the stock thirdgen 02 have a single wire...if you have longtubes i would recommend converting to a 3 wire heated 02's you can buy them off the shelf i ordered one for a 95 chevy 350 pick up those have the 3 wires 2 black and 1 white the white is the signal wire and the black ones can be used either way 1 must be 12v accessorie (power comes on when you turn the key) and the other 1 ground. you will give a better reading this way... but like Aperion said a narrowband isnt all that great it will still give you some AFR reading but if you wanna go all out buy the wideband controller.
Good luck
Old Oct 12, 2011 | 10:45 AM
Verhagen82's Avatar
Car: 82 Firebird
Engine: Boosted LSX
Anyone wanna trade? ahaha
Frozer!!!
Jan 19, 2024 04:55 PM
Vintageracer
Jan 10, 2020 05:33 PM
Reddeath210
Oct 6, 2015 08:20 AM
redmaroz
Aug 16, 2015 11:40 PM
Omega
Aug 10, 2015 12:46 PM
