Head Light Motor Testing
Old Oct 16, 2011 | 02:29 PM
mantaguy's Avatar
Engine: 5.0 EFI
Transmission: THM700R4
Axle/Gears: 277 Posi Speedo
I'm trying to test a set of headlight motors to make sure their good,how would I go about that??
Old Oct 16, 2011 | 05:22 PM
Base91's Avatar
Car: Base 91 'bird
Engine: 3.1 v6
Transmission: 4L60
Axle/Gears: 9-bolt 3.27 & PBR
Re: Head Light Motor Testing
Connect them to a 12v battery. Motor should spin. Then swap wires to opposite terminals and motor should spin the other way.
Old Oct 16, 2011 | 05:34 PM
mantaguy's Avatar
Engine: 5.0 EFI
This is what I did,I unplugged my headlight motors and plugged the ones that need to tested and they run,but are they supposed to keep spinning.the motors started to run with the headlight switch in the off position.Are they supposed to do this,because they aren't installed yet.
Old Oct 16, 2011 | 06:17 PM
Base91's Avatar
Car: Base 91 'bird
Engine: 3.1 v6
Transmission: 4L60
They'll keep spinning as long as they have power. However, there should be no power to the motors with the switch off and the lights all the way up or down. The control module sends power to pop them up or down but cuts the power when they hit the end of their travel. You may need to trace back to the relay and then the control module etc. That's on my '91. Not sure if it makes a difference but what year do you have?
BRoss99
Aug 10, 2025 05:08 PM
eightsixseven
Dec 16, 2024 01:50 PM
Frozer!!!
Jan 19, 2024 04:55 PM
Jae992
Aug 27, 2015 09:07 AM
Omega
Aug 10, 2015 12:46 PM
