Will speedo work after computer removal.
Old Nov 1, 2011 | 07:34 PM
kyle91rs's Avatar
Car: '88 Z Clone
Engine: 305 TBI V8
Axle/Gears: 2.73 Limited Slip
Not sure if this an electronics question or not. I will be removing the ecu this winter in my 1991 rs camaro because I am swapping my tbi 305 toa carb 350. Once this is done, I am aware that my tach won't work but not sure of the speedo because it's electronic. The sensor remains in the trans and I'm not removing anything else but the ecu. Will this cause my speedo to malfunction and will it require rewiring?
Last edited by kyle91rs; Nov 1, 2011 at 07:35 PM. Reason: Left out important info about car
Old Nov 1, 2011 | 11:33 PM
vetteoz's Avatar
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
Re: Will speedo work after computer removal.
Tacho will work , wire goes direct to tacho from coil
See
http://austinthirdgen.org/mkportal/m...ine_wiring.gif
Speedo maybe not.
If like the '730 TPI engines , the VSS signal goes to the ECM 1st ; then is outputted to the gauge
Old Nov 2, 2011 | 05:56 PM
kyle91rs's Avatar
Car: '88 Z Clone
Engine: 305 TBI V8
is there a stand alone unit i can then hook to the speedo or should i convert to a cable controlled speedo. if i go that route, is it difficult and would it cost alot?
Old Nov 2, 2011 | 06:58 PM
Pocket's Avatar
Car: 91 Trans Am
Your 91 will have an electric speedo and TBIs used a buffer box, so you're good on all accounts. You must use a trans with an electric VSS though
Remove the ECM and the speedo will still work fine. V6 and TPI cars for 90-92 have to add a buffer box to drive the speedo when doing a carb conversion
Old Feb 18, 2012 | 05:15 PM
kyle91rs's Avatar
Car: '88 Z Clone
Engine: 305 TBI V8
So just to double check, removing ecu and going with a new motor with an hei distributor is not going to require an aftermarket tach? I have a sunpro stand alone tach I can install if required. Suggestions?
Old Feb 18, 2012 | 11:34 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
None of the gauges in any thirdgen have anything to do with the computer whatsoever.
Old Feb 19, 2012 | 01:36 AM
vetteoz's Avatar
Car: 82 Z28
Transmission: T400
Suggestions?
Depends what you butchered in the engine bay wiring when doing the swap.
At worst you will have to run a new wire from the dist (TACH terminal ) inside to the cluster
You should have kept all your gauges wiring through the firewall anyway
Jorlain
Aug 24, 2022 05:11 PM
Jeremys87
Jul 14, 2022 09:08 PM
jharrison5
Aug 19, 2015 05:53 PM
Irocohio
Aug 12, 2015 08:03 AM
beachrodder
Aug 7, 2015 04:27 PM
