Headlights, well lack of them!
Old Nov 13, 2011 | 06:28 PM
GeniGirl's Avatar
Car: 1987 GTA - the year I was born!
Engine: 5.7
Transmission: auto
Axle/Gears: yeah right?!?!?!
My headlights wouldn't go up so I called my mechanic and he said that I could just crank them up manually. That does not work, what is wrong with them. This blond is getting ticked at this car!
Old Nov 13, 2011 | 07:21 PM
Speed Racer X's Avatar
Car: '09 Pontiac G8 GT - 12.76@109
Engine: 436HP 6.0L
Transmission: 6L80E
Axle/Gears: 2.92
Re: Headlights, well lack of them!
There's a vendor here (I think) that makes a $20'ish kit to fix this. There are a couple of parts inside that wear out and cause what you are experiencing. It's common and an easy fix.
Click on some of the vendor logos on the right of your screen and look for headlight parts and you'll see the kit to fix this.
Old Nov 13, 2011 | 07:38 PM
t-top havoc's Avatar
Car: '87 Camaro
Engine: '92 Carb'd 350
Axle/Gears: factory stock
Take a look at
www.topdownsolutions.com
He has alot of 3rd gen parts.
( edit )
www.Top-DownSolutions.com
lonsal
is the owner
Old Nov 13, 2011 | 07:50 PM
Car: '87 Camaro
Old Nov 14, 2011 | 11:03 AM
gearhead141's Avatar
Car: 1985 Trans Am
Engine: LG4
Axle/Gears: 3.08
I have this very same problem on my '85 T/A. The headlights go up and down just fine with the switch but not manually with the ****.
Old Nov 15, 2011 | 07:07 AM
GeniGirl's Avatar
Engine: 5.7
Transmission: auto
I'm I to understand that I am UNABLE to drive this at night until I get them fixed? So if a gear goes out so they will not go up and down by the switch what the heck good is the **** to manually do it! OK I know their could be electric problems.....but still, come on!
Old Nov 15, 2011 | 08:30 AM
bbsr72's Avatar
Car: 91 formula
Engine: 350 tpi
Transmission: auto
Axle/Gears: poss
i fixed mine with rubber hose. but before that i had to turn the stupid things forever to get them up.
Old Nov 19, 2011 | 02:56 PM
Maverick H1L's Avatar
Car: 2003 Hyundai Tiburon GT
Engine: 2.7L V6
Transmission: 6-speed
Axle/Gears: 4.41
Those ***** are junk by now (stripped out). Pull them off and use a pair of pliers on the shaft underneath. Oh, and then unplug the motors to keep them from coming back down (if they're going to) when you turn the lights off the first time. :edit: And don't worry that not having the ***** is going to hurt the motors. I never knew there were ***** on the motors until I bought a used one due to the issue mentioned below, and never had a problem with the motors working in the 8 years I've had my car (except for those plastic bushing things breaking).
Be warned that if the motors need to be rebuilt that the screws holding the motor together (3 in the side housing and 2 on the motor can at the top) most likely will break. If not, use anti-seize to prevent this in the future.
Old Nov 19, 2011 | 05:41 PM
luvofjah's Avatar
Car: 91 Black Formula KR
Engine: 305 TPI R69/G92
I used the top down solutions parts / fix and they are new again... the pieces the round bushings they replaced had long dried up and turned to powder (you'll find plenty inside the motor)... but after fix, better than new...
Rafael
Old Nov 19, 2011 | 07:35 PM
GeniGirl's Avatar
Engine: 5.7
Transmission: auto
Thanx guys, I LOVE DRIVING this car, but its got little things that r driving me nuts! p.s. "I look real good in that car", oh thats a quote...lol....
oil pan 4
Fabrication
Oct 6, 2015 11:56 AM
J. Chris Davis
Interior Parts Wanted
Sep 28, 2015 11:55 AM
