fuel pump
Old Dec 4, 2011 | 03:53 PM
emerald91fbird's Avatar
Car: 1991 firebird
Engine: 3.1 l v6 mpi
Transmission: auto
fuel pump
okay so i bought a 91 bird 3.1l v6 the fuel pumps runs great till u turn on the lights or air conditioner the pump is hot wired their is a grey wire crimped to a wire run into fuse box but i have a grey wire that isnt connected to anything and i also have a red i one believe they are all related any ideas guys?????
Old Dec 4, 2011 | 04:46 PM
travis401's Avatar
Car: 91 Camaro RS
Engine: empty bay (for now)
Transmission: Built T-56
Axle/Gears: 3.42 stock posi disc
Re: fuel pump
the grey wire is the power wire that runs from the main bulkhead connector under the carpet all the way back to the fuel pump. my guess is that car has a fuel pump relay issue and the PO hotwired the pump instead of fixing it.
Old Dec 4, 2011 | 04:47 PM
travis401's Avatar
Car: 91 Camaro RS
Re: fuel pump
http://austinthirdgen.org/mkportal/m...ine_wiring.gif
Old Dec 4, 2011 | 04:49 PM
Car: 1991 firebird
Transmission: auto
Re: fuel pump
ok if i test it what should be the volts/ amp comeing out of it
Old Dec 4, 2011 | 04:53 PM
travis401's Avatar
Car: 91 Camaro RS
Re: fuel pump
the fuel pump relay should have a 12v constant on the orange wire and a 12v on the grey wire when the ecm triggers the relay.
Old Dec 4, 2011 | 04:55 PM
Car: 1991 firebird
Transmission: auto
Re: fuel pump
so to test i should prime the pump???
Old Dec 4, 2011 | 05:00 PM
travis401's Avatar
Car: 91 Camaro RS
Re: fuel pump
the red wire is a test circuit to prime the pump. but if the pumps power wire (gray) isnt connected to the circuit, its not gonna do anything.
Old Dec 4, 2011 | 05:38 PM
Car: 1991 firebird
Transmission: auto
Re: fuel pump
ok..... the grey wire is putting out about 11 volts should i just reattach it to the other grey wire????
Old Dec 4, 2011 | 05:43 PM
travis401's Avatar
Car: 91 Camaro RS
Re: fuel pump
give it a shot and see what happens
Old Dec 4, 2011 | 05:51 PM
Car: 1991 firebird
Transmission: auto
Re: fuel pump
i just dont see why they would do it tho?
Old Dec 4, 2011 | 05:55 PM
travis401's Avatar
Car: 91 Camaro RS
Re: fuel pump
some people do crazy things to these cars for reasons noone will ever understand. if it works go with it, if it doesnt then we can help you fix whats wrong instead of just rigging it to run.
Old Dec 4, 2011 | 05:59 PM
Car: 1991 firebird
Transmission: auto
Re: fuel pump
ok i let u know
Glowsock
Jul 24, 2025 03:15 PM
92camaroJoe
Jul 29, 2023 07:57 PM
RazorN8
Jan 7, 2022 11:44 AM
beachrodder
Aug 25, 2015 08:05 AM
92camaroJoe
Aug 13, 2015 06:07 AM
