power door locks don't work and radio turns on but no sound
Old Dec 24, 2011 | 11:24 AM
KITT1983's Avatar
Car: 1983 Pontiac Trans Am Daytona 500
Engine: Crossfire 305ci V8
Transmission: Jasper 700R4 4 speed Automatic
Axle/Gears: 3.23 limited slip/posi
My power door locks don't work. the Power Door Locks do not even make a click. the radio turns on but with no sound and does not recognize the Sirius satellite radio adapter. I have Pioneer P5000DVD. the power windows and power mirrors work.
Old Dec 24, 2011 | 12:56 PM
85irocinjected's Avatar
Car: 1991 RS
Re: power door locks don't work and radio turns on but no sound
You radio has power but no sound..Check your speaker wiring. If your deck is working correctly then you have an issue with the speaker wiring or the deck output it self. As for the door locks, check your fuses.
1991 Chevrolet Camaro Car Radio Wiring Diagram
Car Radio Battery Constant 12v+ Wire: Orange
Car Radio Accessory Switched 12v+ Wire: Yellow
Car Radio Ground Wire: Black
Car Radio Illumination Wire: Gray
Car Stereo Dimmer Wire: Light Brown
Car Stereo Antenna Trigger Wire: Pink
Car Stereo Amp Trigger Wire: N/A
Car Stereo Amplifier Location: N/A
Car Audio Front Speakers Location: Dash
Left Front Speaker Positive Wire (+): Tan
Left Front Speaker Negative Wire (-): Gray
Right Front Speaker Positive Wire (+): Light Green
Right Front Speaker Negative Wire (-): Dark Green
Left Rear Speaker Positive Wire (+): Brown
Left Rear Speaker Negative Wire (-): Yellow
Right Rear Speaker Positive Wire (+): Dark Blue
Right Rear Speaker Negative Wire (-): Light Blue
Door lock schematic...
Attached Thumbnails power door locks don't work and radio turns on but no sound-lockschematics1.jpg
Old Dec 24, 2011 | 01:34 PM
KITT1983's Avatar
Old Dec 24, 2011 | 01:43 PM
KITT1983's Avatar
thanks I will check my fuses
BRoss99
Aug 10, 2025 05:08 PM
Frozer!!!
Jan 19, 2024 04:55 PM
1992 Trans Am
May 10, 2023 07:19 PM
OLDYELLR
Car Audio
Sep 30, 2015 07:10 PM
BrianI
Aug 9, 2015 11:52 AM
