VATS Key Question
Car: 90 IROC-Z
Engine: LB9
Transmission: M5 5spd
Axle/Gears: 3.42 POSI
VATS Key Question
I just put a new column in my 90 IROC because the last owner cut out all the air bag stuff for a momo wheel. I want the orginal stuff in the car. My question is I did the measuring of the key on mine and the new key and my key measures 749 and my new key measures 1470. 749 isa between number do I need a key blank #3? I am confused.....
Car: 1989 Iroc-z
Transmission: Auto 700R4
Axle/Gears: 9 bolt - 2.77
Re: VATS Key Question
Since you have the original key which I'm guessing it started the car before and now you replaced the column which I'm guessing you have a key for it and the ohms are different for each key. Why not just swap the lock cylinder from the old column to the new column. Then you can use your original key.
Car: 90 IROC-Z
Engine: LB9
Because my old column has a push button in the ignition switch to release the key and I really hate it, and the new column doesn't.
Street Lethal
Apr 30, 2019 12:14 PM
