Wiring HEI on '91 RS.
Old Feb 21, 2012 | 09:26 PM
RSCAMAROGUY91's Avatar
Car: 1991 RS Camaro w/ Factory T-Tops
Engine: Built 355 ci SBC w/ Carb
Transmission: Borg Warner T-5
Axle/Gears: 4.10 with Posi-Trac
So, after getting the 355 put in my '91 RS, I've got pretty much everything done other than wiring the distributor. I have searched on here, and pretty much everything I've read is a little muddy. If I've read everything correctly the pink wire coming from the wiring harness is the one that runs to BATT terminal on the HEI distributor. In addition the white wire coming from the wiring harness runs to the TACH side of the HEI distributor. Like I said I believe I've read this right, but I want to be 100% sure before I start the wiring because I only want to do this once.
Old Feb 21, 2012 | 10:55 PM
vetteoz's Avatar
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
Re: Wiring HEI on '91 RS.
Correct
Old Feb 22, 2012 | 09:28 AM
Thanks! That's what I thought, but I wanted to be 100% sure.
Frozer!!!
Jan 19, 2024 04:55 PM
Streetstuff
Sep 7, 2015 09:23 AM
stalkier
Aug 21, 2015 01:54 AM
midias
Aug 15, 2015 05:07 PM
stalkier
Aug 7, 2015 04:49 AM
