bad fan motor,relay or temp switch?
Old Mar 8, 2012 | 10:01 PM
StringRust's Avatar
Car: '89 Camaro Rs/ '87 Z28
Engine: 305 c.i. TBI/ 305 c.i. 4bbl
Transmission: 700r4/T5
Axle/Gears: 3.73 posi/ 3.73 posi
Noticed on my way home from work my camaro started to run hot. Apparently the fan is not coming on. Doesn't even come on when I turned on the a/c. Unplug the connector from the relay and jumped the 2 terminals. With the car off or with the ignition on and a/c switched on something clicks and draws power however the fan does not spin. With ignition on and a/c switched OFF there is no click and fan does not work when I jumped the terminals. Is this a bad fan motor?
Thanks!
Old Mar 8, 2012 | 10:49 PM
vetteoz's Avatar
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
Re: bad fan motor,relay or temp switch?
The terminals on the motor itself?
If you put 12V direct to the motor and it didn't work then most likely a bad motor
Old Mar 9, 2012 | 12:02 AM
StringRust's Avatar
No the terminals on the connector that goes to the relay. Tomorrow I'm going to unplug the fan and run jumpers from fan to battery.
BRoss99
Aug 10, 2025 05:08 PM
eightsixseven
Dec 16, 2024 01:50 PM
RazorN8
Jan 7, 2022 11:44 AM
89GTAOz
May 16, 2020 09:31 AM
TA8487
Aug 16, 2015 12:21 PM
