Please help identify connectors
Old Mar 28, 2012 | 08:46 PM
Camaropower169's Avatar
Car: 1984 Camaro Z28
Engine: 4 bolt 350
Axle/Gears: Richmond 3.73 spool 10 bolt
Can anyone help me identify these connectors to see if they are supposed to be connected to anything? The two wire connector has a green and black wire with a diode I believe? The four wire one is labeled abcd wire are as follows
a - White
b - Pink/White
c - tan
d - Black
Background info on car, It is an 84 z28, origionally L69 305, now 350, vacuum distributor, holley 750 vacuum advance, ac removed (previous owner) cruise control removed (likewise) and the origional carb/dist was removed before I got it. Now I'm trying to get the Wiring straightened out (Loose ends from what appears to be a hack job removing the cc carb)
Also out of curiousity, if my car doesn't have the cc carb, will my tcc work still? The computer is still in the car, I'm just not sure if a sensor calls for it to be locked up or not. Are the vacuum sensor and baro sensor still needed for a non-cc carb?
Attached Thumbnails Please help identify connectors-connector-1.jpg   Please help identify connectors-connector-2.jpg
Old Mar 28, 2012 | 09:12 PM
Tuned Performance's Avatar
Community Influencer
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
Re: Please help identify connectors
ac compressor and distributor connection.
Old Mar 28, 2012 | 09:30 PM
Engine: 4 bolt 350
2 wire is ac and 4 wire is distributor?
Old Mar 28, 2012 | 09:36 PM
Engine: Lb9
Transmission: M20
Old Mar 28, 2012 | 09:50 PM
Engine: 4 bolt 350
Well that stinks, that connector doesn't look like the connector that fits on the distributor I have lol so i'm sure the old distributor was rigged up somehow
Old Mar 29, 2012 | 03:31 PM
Engine: 4 bolt 350
Can anyone else add any info/insight?
91 SrS
Oct 7, 2015 04:32 PM
TMZIrocZ350
Oct 7, 2015 12:09 PM
meeklay812
Oct 1, 2015 03:46 PM
tmork454
Sep 29, 2015 06:33 PM
Gordonr1973
Sep 29, 2015 11:59 AM
