No power to fuse block? I don't know what the problem is
Old Apr 30, 2012 | 07:14 PM
Jfinnkma91's Avatar
Car: 1984 Chevy Camaro
Axle/Gears: 7.5in 10 bolt with 3.08
It's a chevy camaro with a 305. I took the engine out to rebuild it and took many many picture. Now I hooked it all back together, the starter has power. So does the alternator, the other wires to the starter are correct. I tried starting it an notice-----no headlights, no brake lights. No start.
I pulled out my voltmeter and there is power to the starter and alternator and the circuit is complete, but I then check the fuse block and there is no power there.
Any have any advice or maybe a schematic?
Old May 14, 2012 | 09:34 AM
NINÅ's Avatar
Engine: ► 400 KUBES ◄
Transmission: 765R4
Axle/Gears: EATON POSI 4.56
No Power This Hour
No doubt by now you have looked at the battery wire to the junction block and even cleaned the connections.
However you might have accidentally caused a temporary short when working on the car.
Using a voltmeter or test light
(the type for testing for voltage, not a continuity tester) probe both sides of all the fusible links to make sure power is passing thru.
Fusible Links usually look like a one inch plastic rod in line with the wire.
Happy Racing!
How Come Some Drivers On The Street Don’t Know How To Make A Turn In One Direction Without Starting By Turning In The Opposite Direction?
BRoss99
Aug 10, 2025 05:08 PM
Ghettobird52
Jul 5, 2024 11:18 PM
jhawkeye
May 25, 2022 06:33 PM
theshackle
Mar 5, 2017 06:37 PM
Reborn756
Sep 4, 2015 03:42 AM
