Pulled Digital Dash out reinstalled and now no Speedo or TAch Help
Old May 4, 2012 | 09:35 PM
MUSKOKA 87 GTA's Avatar
Car: 87,88,89 GTA
Engine: 305+350 TPI
Transmission: AUTOMATIC
K Guys i pulled the digital dash out of my car today and reinstalled and now no Tach or speedo anyone have this prob ?? no i did not spray with contact film
Old May 5, 2012 | 08:57 AM
mrrman's Avatar
Re: Pulled Digital Dash out reinstalled and now no Speedo or TAch Help
I would say may sure that the 3 back connectors are on tight
Old May 8, 2012 | 01:13 AM
88 TA GTA's Avatar
Car: MSD Dist., Crane Hi 6 ignition
Engine: 350 - 50 over, S/R Torquer Heads
Transmission: T56 - Originally a 700R4
Axle/Gears: 9 bolt posi with 370
Is it possible that when you put it back in the digital cluster wasn't aligned 100%? There are two sets of wiring pins ( one on each side of the digital cluster these pins go into the wiring harness that sit in the dash in the exact spot.
I would pull it back off and check all the wiring pins on the back of the gauge cluster and make sure none of these were bent when you reinstalled.
Jorlain
Aug 24, 2022 05:11 PM
The_Phoenix
Feb 4, 2016 07:10 AM
Pilotrick50
Sep 2, 2015 12:48 PM
TA8487
Interior Parts Wanted
Aug 23, 2015 01:34 PM
beachrodder
Aug 7, 2015 04:27 PM
