MSD WIRING help
Old May 14, 2012 | 09:03 AM
FRMULA88's Avatar
Car: 1988 Formula
Engine: 421 Little M block
Transmission: TH400 w/brake
Axle/Gears: 9" 4.30s, Wilwood discs, 28X10.5-15
MSD WIRING help
I have this tan wire that is part of the harness going to the coil... old spark advance wire ? (cap off and tuck in harness)
I have a MSD pro billet dist. I am going to connect the tach signal from the dist. to the green and purple harness from my 6AL box.
I have the aftermaket MSD blaster coil made for the F-body...
color coded MSD box wiring...
black from MSD taps to car black (coil - )
orange from MSD tap to car orange (coil +)
white not used.. ( using purple & green)
red from MSD tap to heavy pink or (ignition )
how does the OEM tach interact with this so the tach is functional ?
Thanks,
Attached Thumbnails MSD WIRING help-img00342-20120513-2140.jpg   MSD WIRING help-2012-05-08-001.jpg
Old May 14, 2012 | 08:38 PM
FRMULA88's Avatar
Car: 1988 Formula
Re: MSD WIRING help
bump
stalkier
Dec 6, 2015 11:25 PM
LittleFranks
Sep 17, 2015 12:22 PM
overdriv
Aug 20, 2015 03:52 PM
midias
Aug 15, 2015 05:07 PM
tartagliaz28
Aug 15, 2015 10:59 AM
