Headlight motor turning wrong direction
Old May 19, 2012 | 03:54 PM
blue birdy 87's Avatar
Car: White 84 z28
Engine: Chevy 350
Axle/Gears: Posi and?
Hey I just used the headlight motor rebuild kit from topdownsolutions and the passenger side light is going good, up and down fine. The drivers side however is turning the wrong direction. I turn headlights on, it goes down. I turn them off, it goes up. Any suggestions? Thanks
Old May 19, 2012 | 04:30 PM
henryd3's Avatar
Car: 92 Camaro RS
Engine: LO3
Axle/Gears: stock
Re: Headlight motor turning wrong direction
You have the wires reversed somewhere
Old May 19, 2012 | 04:37 PM
Car: White 84 z28
Engine: Chevy 350
I dont remember reversing them but its possible. Where would be an easy spot to switch the wires?
Old May 19, 2012 | 05:01 PM
henryd3's Avatar
Car: 92 Camaro RS
Engine: LO3
Axle/Gears: stock
Don't know, I don't have a Firebird. Where did you connect them? Seems like s good spot
Old May 19, 2012 | 05:34 PM
Car: White 84 z28
Engine: Chevy 350
I just took some wires and stuck em in each end opposite way and it works now. Oh and i red neck taped it in place now
Old May 19, 2012 | 06:02 PM
henryd3's Avatar
Car: 92 Camaro RS
Engine: LO3
Axle/Gears: stock
Cool, well if not soldered together you might at least use crimp connectors so they keep working. Have fun!
BRoss99
Aug 10, 2025 05:08 PM
Ghettobird52
Jul 5, 2024 11:18 PM
1992 Trans Am
May 10, 2023 07:19 PM
evilstuie
Jan 9, 2020 08:29 PM
Tony Ferrarri
Aug 11, 2015 07:59 PM
