Help with wipers on my Berli
Old Jun 2, 2012 | 03:32 PM
DarkStarr's Avatar
I have an 83 Berlinetta with a carbbed V-8, auto trans, and the non-digital dash. The PO removed the ECM and related systems. Other unknown mods may exist All of the cabin systems operate nominally with the exception of the wipers. The wipers and wash work in all switch positions while the ign is in the ACC position but not at all in the run position. Any help would be greatly appreciated.
I drive it because I can.
Old Jun 4, 2012 | 03:39 PM
NINÅ's Avatar
Engine: ► 400 KUBES ◄
Transmission: 765R4
Axle/Gears: EATON POSI 4.56
Windshield Wiggler
No telling what the PO did.
Here’s what you can do:
Verify you have no power on the
WIPER fuse in the RUN position.
Once verified, at the back of the fuse block connect the input side of the
RADIO fuse to the input side of the WIPER fuse.
You can determine the input side of the aforementioned fuse by removing the fuse, then measuring for voltage with the key in the RUN position.
Happy Racing!
Make Noise, Turn Left, Repeat
Old Jun 4, 2012 | 09:52 PM
DarkStarr's Avatar
Re: Windshield Wiggler
Thanks for the good words. Turns out there is power at the wiper fuse in the run position. Turning on the wiper switch in the ing run pos gets a good click at the starter motor. Turn off the wiper switch and put ign switch in off and the wipers cycle out of then into park.
Old Jun 5, 2012 | 09:32 AM
DarkStarr's Avatar
Re: Help with wipers on my Berli
Wiper issue resolved! Incorrect wiring on the part someone in the cars past. I was able to correct it thanks to info I found on thirdgen! Many thanks to all who have shared their time and knowledge!!
This looks like the beginning of a beautiful friendship.
Hal87
Exterior Parts Wanted
Nov 8, 2015 03:40 PM
Hal87
Sep 26, 2015 09:26 PM
adelane
Sep 9, 2015 08:51 PM
