auto meter gauges
Old Jun 4, 2012 | 09:16 PM
clean92rs's Avatar
Car: 92 camaro RS
Engine: Vortec 355,262/268 cam,670holley
Transmission: 5speed
auto meter gauges
does anyone have any pics and info on how to wire the auto meter oil pressure gauge and where you put it? i ordered the harness from classic dash but i am clueless on how to run the wire from the sender up.
Old Jun 5, 2012 | 03:51 PM
6SIX6's Avatar
Car: 89 IROC
Engine: LSX 6.0 370, TU2 Cam, Fast intake
Transmission: T56 w/ lots of goodies
Axle/Gears: 8.8, Posi, 4.10, 31 Spline
Re: auto meter gauges
power (12v switched) , ground and 1 wire from the gauge to the sender if its electric. Its that simple
Old Jun 5, 2012 | 04:46 PM
built91Z28's Avatar
Car: 1991 Camaro Z28
Engine: 357, Canfield heads, solid roller,
Transmission: Upgraded 03 Cobra T56
Axle/Gears: 9" 3.50 gears and Detroit Locker
Yep. Then the two wires for the light inside.
Where you put it is up to you. I made an entire new panel for all my new guages.
Old Jun 5, 2012 | 08:38 PM
clean92rs's Avatar
Car: 92 camaro RS
thats what im concerned with is the single wire from the sender to the gauge. did you just run a sep. wire or should it be with the wire harness i bought from classic dash?
Old Jun 5, 2012 | 09:33 PM
built91Z28's Avatar
Not sure what the harness you bought is for, but you can just run a single wire on its own to the sending unit. Just as long as you have a wire going from the gauge to the sending unit, that's what matters.
Old Jun 5, 2012 | 10:08 PM
clean92rs's Avatar
Car: 92 camaro RS
ok thanks
Bubbajones_ya
Jul 6, 2024 08:32 PM
88rscamar0
Sep 23, 2015 09:08 PM
eustodp
Sep 20, 2015 05:09 PM
TrevinE
Sep 14, 2015 03:20 PM
86IROC112
Sep 11, 2015 04:04 PM
