Can I just run my fuel pump on a switch?
Old Jun 8, 2012 | 04:44 PM
Irockirocs's Avatar
Car: 86 iroc
Engine: 305 tpi
My connector under the cars by the tank is only getting 8.5 volts can I just run a 12v switch to power my pump? Or does the relay or computer need to see eachother? Please help 86 tpi 305 camaro
Old Jun 8, 2012 | 05:45 PM
rlewi771's Avatar
Car: 86 IROC
Engine: 350 ZZ4
Transmission: TKO-600
Re: Can I just run my fuel pump on a switch?
if thats what you want to do go for it. Computer will not be affected by it
Old Jun 8, 2012 | 06:03 PM
ZZ3 Z28's Avatar
Car: 1986 Z28
Engine: ZZ3
So you want to turn the fuel pump on and off with a switch? Is that correct? A switch that you physically flip on and off to control the fuel pump? So if you get out of the car and forget to turn off the fuel pump, the fuel pump is stilling running, or if you get into an accident, the fuel pump is still pumping fuel to a smashed up car with you possibly incapacitated in the driver seat? ? Am I missing something here?
Old Jun 8, 2012 | 07:30 PM
Irockirocs's Avatar
Car: 86 iroc
Engine: 305 tpi
Im stuck in south central and I need to get this car running enough to get it home to minnesota before my grandmas funeral on the 18th and I hate wiring
Old Jun 9, 2012 | 02:25 PM
zzjakect's Avatar
Car: 1985 Z28
At the minimum run the twelve volts from the ignition wiring so it will not run if the key is not on. It is still a safty issue in the case of a crash, but for a one time drive it's your call. If you make it, run the wiring so when the engine shuts down it shuts off the pump. Good luck.
RazorN8
Jan 7, 2022 11:44 AM
theshackle
Mar 5, 2017 06:37 PM
beachrodder
Aug 25, 2015 08:05 AM
justin57
Aug 20, 2015 07:05 PM
Kaweh
Aug 9, 2015 02:54 PM
