hatch release button
Old Jun 23, 2012 | 09:51 AM
tazz3871's Avatar
Hey guys I owned an 87 GTA and I have the following issue when I press the hatch release button the hatch doesn't release it will open with the key is there a relay or fuse for this hatch release button thanks any help is appreciated
Old Jun 23, 2012 | 10:24 AM
DJP87Z28's Avatar
Car: 1987 Black IROC-Z (SOLD)
Re: hatch release button
One question. When you close the hatch, dose the hatch motor pull it down???
Old Jun 23, 2012 | 11:23 AM
tazz3871's Avatar
recently happened where it didn't and now it does
Old Jun 23, 2012 | 12:49 PM
DJP87Z28's Avatar
Well what is it??? Your reply is sort of vague....
Old Jun 23, 2012 | 02:22 PM
SweetRevelation's Avatar
Car: '89 GTA
what he means is that sometimes it works and sometimes it doesn't, this goes for both the hatch release button and the motor-pull-down itself.
I've had the same issues and even still with a different rear hatch pull-down-motor installed... although it actually functions more frequently now...
Old Jun 23, 2012 | 03:54 PM
tazz3871's Avatar
no the hatch release does not work but the hatch pull does
Old Jun 23, 2012 | 06:01 PM
DJP87Z28's Avatar
Since the pull down has power, I would just replace the switch. I also hope you did not do any work on the center console by chance??
Old Jun 24, 2012 | 06:02 AM
tazz3871's Avatar
No work has been done on the centre console what would that have to do with the hatch switch anyways the switch is on the dash
Old Jun 24, 2012 | 08:30 AM
TreeFiddy's Avatar
Car: '86 TA
Engine: '74 350
Axle/Gears: 2.77
Ok, so hatch pull-down works but hatch release doesn't. Got shifter in P/N if auto or park brake on if manual? Acc fuse intact?
Old Jun 24, 2012 | 12:19 PM
tazz3871's Avatar
yes to all of the above
Old Jun 24, 2012 | 12:30 PM
BADASS91B4C's Avatar
Car: 1991 B4C, 1992 RS
Engine: 355, 305
Transmission: 700r4, 700r4
Axle/Gears: 3.73, ?
my car is doing the same thing. hatch motor pulls down but the switch on the center console wont open it only the key
Old Jun 25, 2012 | 02:19 AM
TreeFiddy's Avatar
Car: '86 TA
Engine: '74 350
Axle/Gears: 2.77
Does the release solenoid on the hatch motor click when you push the button?
Old Jun 25, 2012 | 05:17 PM
NINÅ's Avatar
Engine: ► 400 KUBES ◄
Transmission: 765R4
Axle/Gears: EATON POSI 4.56
Rear Passenger Ejection Button
is there a relay ….. for this hatch release button
Yes.
The hatch release relay might be located under the console near the rear.
Make sure the relay coil receives power when the Hatch Release is pressed.
Check all connectors going to the unit to make sure the contacts are clean and tite.
Also, check the motor brushes for wear.
Happy Racing!
He Must Have Been Be Cheating - Because I Was And He Almost Beat Me.
Old Jun 25, 2012 | 05:48 PM
tazz3871's Avatar
no i don't hear a sound when I press on the button
Old Jun 25, 2012 | 06:18 PM
Engine: 355, 305
Axle/Gears: 3.73, ?
mine doesn't make a sound either
Old Jun 25, 2012 | 10:41 PM
TreeFiddy's Avatar
Car: '86 TA
Engine: '74 350
Axle/Gears: 2.77
Find and check the relay, like Nina said.
Power flow goes from batt, to Acc fuse, to release switch, to hatch relay coil, and then back to ground thru either the p/n switch (auto) or park brake switch (manual).
Hatch relay then switches power to the release solenoid coil in the hatch motor.
Might have to break out the voltmeter and track it, power is getting interrupted somewhere.
Old Jun 26, 2012 | 03:30 PM
tazz3871's Avatar
No there's no sound coming from the rear at all
Old Jun 26, 2012 | 03:31 PM
tazz3871's Avatar
great thanks I looked it up on the weekend and keep you posted
Old Jun 26, 2012 | 03:32 PM
tazz3871's Avatar
Re: Rear Passenger Ejection Button
Originally Posted by NINÅ
Yes.
Happy Racing!
Thanks Nina will get on it this weekend will keep you posted
Old Jun 29, 2012 | 09:40 AM
lonsal's Avatar
Axle/Gears: 3.45, 3.27, 3.27
Your statement implies that the if the hatch pull-down has power, then the hatch release should also have power. They are on separate fused circuits.
Lon
Old Jun 29, 2012 | 01:52 PM
STREETDEMON's Avatar
Car: 91 Z28
Engine: 6.0L LQ9
Axle/Gears: Dana 44 3.92
So if I did an LSX/T56 swap in my L98/Auto car, then I have killed the necessary connection from the p/n switch? That would explain why it doesn't work now...I'll have to try it with the clutch pushed in and that switch engaged.
Old Jun 30, 2012 | 12:20 AM
TreeFiddy's Avatar
Car: '86 TA
Engine: '74 350
Axle/Gears: 2.77
Sounds possible, but if you've re-wired there no guarantee it's ended up connected to the clutch switch either. You might have to get in there, find the original wire to the p/n switch, and connect it to the park brake switch.
Don't just ground it, this creates the possibility of being able to accidentally hit the button and pop the hatch while moving.
Old Jun 30, 2012 | 09:53 AM
onthedownlow's Avatar
Car: 1984 Camaro Berlinetta
Engine: 355
Axle/Gears: Australian 9 bolt 3.27 posi
My hatch release wont work unless I have the e brake on. Thanks to this thread I now know that this is normal for a third gen with a standard transmission.
Old Jul 2, 2012 | 07:41 AM
tazz3871's Avatar
Finally completed my search and thanks Nina and Treefiddy for all of your inputs I discovered that the relay is the culprit. Thanks a bunch
Old Jul 2, 2012 | 08:08 AM
Car: 91 Z28
Engine: 6.0L LQ9
well, mine works with the clutch pushed in....thats good to know! even a blind hog gets an acorn once in a while.
Old Jun 18, 2015 | 10:06 PM
jdhh74's Avatar
Car: 1984 Trans Am
Engine: L69
Hi - mine works with the clutch pushed in too (1984, manual).
It will does this with the e-brake on or OFF.
I'm assuming that's not right. Why would the clutch switch be acting like the parking brake switch in this case? Are they part of the same circuit?
Old Jul 9, 2015 | 09:15 AM
rkg8554's Avatar
Car: 87 Iroc Z 28
Engine: 355/ 600 Holly
Transmission: 700R4 shift kit & vette servo
Axle/Gears: 9 bolt 3;70s
sorry to hijack but I have a question, my hatch release switch works and my hatch opens with switch, but the latch does not move up when the release switch unlocks the hatch. I installed a used but very good condition latch assembly. When installed the latch was in the up position. I closed the hatch and everything worked as it should. But know the the latch stays in the lower position. Elec release works and I close like a manual latch. I know with the old latch that you do not slam the hatch but lightly let it make contact with the latch and it pulls the hatch closed. When releasing the hatch the latch would travel up and then release the hatch.Any ideas ?
Old Jul 9, 2015 | 06:25 PM
Drew's Avatar
Push the tab in the latch down with your finger, to see if it's all the way down. If the pulldown doesnt get all the way down, it wont reset for the reverse, and it wont come back up.
Old Jul 10, 2015 | 07:24 PM
rkg8554's Avatar
Car: 87 Iroc Z 28
Yes it is all the way down, so I am guessing the reversing switch is bad.
Old Jul 9, 2020 | 02:36 PM
Lively's Avatar
Car: 1989 Camaro RS
Engine: 305 V8
Transmission: 5 Speed Manual
Maybe someone can help with my issue...
Same problem, hatch wont open with switch. Pull down motor is working, relay clicks when parking brake is engaged not when disengaged (so thats working i assume), Does not do anything different when i push in clutch like others have said.
Old Jul 13, 2020 | 12:50 AM
lonsal's Avatar
OK, so the hatch release circuit has power. Check that there is a ground wire running from the 10mm screw attaching the hatch release solenoid to the body ground location below the pull-down unit. If it is missing that's your problem. The solenoid needs that ground wire in place to function since it is electrically isolated from ground by the plastic guides in the track.
Lon
Jorlain
Exterior Parts Wanted
Jun 29, 2017 11:04 PM
jrdturbo
Mar 31, 2016 02:58 PM
sleprock
Interior Parts Wanted
Oct 3, 2015 11:01 PM
formula00ra
Sep 28, 2015 11:50 AM
IROCZDAVE (88-L98)
Sep 22, 2015 02:22 PM
