Have to flick ignition for fuel gauge to work?
Old Jun 28, 2012 | 01:42 AM
J0hn_J0hn08's Avatar
Car: 1986 Iroc-Z
Engine: 355
so my car picked up a problem today, when i turn it on the gas gauge will read then slowly it will drop down to 0.
i have to flick the ignition for it to pick up and start reading again.
My car is a 1986 iroc, could it be a bad ground? if so what wire can i ground out to provide a more solid connection? or what could it be?
Old Jun 28, 2012 | 01:37 PM
Car: 1986 Iroc-Z
Engine: 355
Re: Have to flick ignition for fuel gauge to work?
anyone?
Old Jun 28, 2012 | 01:46 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
What does flick the ignition mean?
Old Jun 28, 2012 | 07:27 PM
Car: 1986 Iroc-Z
Engine: 355
means i have to turn the ignition on and off to get the gauge to start reading
Old Jun 28, 2012 | 07:41 PM
NemeSS-TyranT's Avatar
Car: 02 SS
Engine: 408 TT (1108rw-93/m1)6700rpm
Transmission: TH400(slipping)
Axle/Gears: 12bolt/3.42(whines😠)
Sounds like ground.
On my truck had similar problem. Chased grounds and connections.
Turns out the solder on wires for floater, severed. It was a contact issue at floater wiring in the tank
Old Jun 28, 2012 | 11:42 PM
Car: 1986 Iroc-Z
Engine: 355
freshened up my grounds today, seems to have solved the issue, hasnt happened again since. Fingers crossed hopefully that was the end of that.
BRoss99
Aug 10, 2025 05:08 PM
Ghettobird52
Jul 5, 2024 11:18 PM
Frozer!!!
Jan 19, 2024 04:55 PM
9192camaro
16
Feb 3, 2019 12:21 AM
justin57
Aug 20, 2015 07:05 PM
