Cables from the firewall??
Old Jul 4, 2012 | 09:25 AM
dank0702's Avatar
Car: 1985 Camaro Z28
Engine: 305 with 4BBL
Transmission: 5 Speed
Anyone know where/what these cables go to? Found them tucked under the brake booster awhile after I bought the car, go figure!
Old Jul 4, 2012 | 01:18 PM
Iroczracer's Avatar
Car: 1989 IROC Camaro
Engine: Stealth Ram 355
Transmission: WC T-5
Axle/Gears: Torsion 3.42 Posi
Re: Cables from the firewall??
The ones I have run through the firewall to the cruise control
Old Jul 4, 2012 | 01:47 PM
dank0702's Avatar
According to my RPO codes mine didn't come with cruise control and I do not have the vacuum lines for and the bracket on the throdle wire doesnt have a spot for cruise. But my turn signal rod has cruise on it and the wires and bushing on the firewall look factory. Wonder if the owner was trying to add it or what...
Old Jul 6, 2012 | 05:59 PM
Tibo's Avatar
Car: 1991 Z28 Vert
Engine: 383 single plane efi
Axle/Gears: 8.8 with 3.73s
What do they go to inside the car? Looks like a job someone did once before you owned it.
Old Jul 6, 2012 | 06:38 PM
Fixer9's Avatar
From looking at the wiring diagrams it looks like the plug should go to the fog light relay in the underhood electrical center.
Old Jul 6, 2012 | 07:58 PM
dank0702's Avatar
No fog light RPO code, no fog light switch, and louver style grill.. Granted, doesnt mean someone didnt try to add it or change it.
Old Jul 6, 2012 | 08:56 PM
Tibo's Avatar
Car: 1991 Z28 Vert
Just follow them inside the car, that will be the biggest clue.
armybyrd
Carburetors
Oct 20, 2015 03:57 AM
TMZIrocZ350
Oct 7, 2015 12:09 PM
mcfastestZ28
Oct 1, 2015 11:23 AM
rs_z28_vert
Sep 30, 2015 09:47 PM
mfp189
Sep 27, 2015 09:25 AM
