Is this the fuel pump relay?
Old Jul 11, 2012 | 06:16 PM
xavier_pr84's Avatar
ok so far gas pump is working distributor cap and rotor replaced i was surfing the web reading looking up now my next step is the fuel pump relay i read that its near the brake cylnder anyway i took a pic of what i think is the fuel pump relay on the left but i noticed that one of the wires were cut and feeds into the radiator fan my question is what relay is this? is it the fuel pump relay,its the one on the left and what is that wire thats cut
Old Jul 12, 2012 | 01:56 PM
henryd3's Avatar
Car: 92 Camaro RS
Engine: LO3
Axle/Gears: stock
Re: Is this the fuel pump relay?
There are two relays next to each other there. The fan relay has four wires going to it and the fuel pump relay has five. They used to be mounted on that bracket on the firewall
Also looks like someone replaced the burnt-out relay with a newer one since all the wires are white. Fan relay has four wire coming to it . Big red or orangish for battery positive. Big black with red stripe supplies 12 volts back to the fan. Small tan or gray or something wire is switched 12 volts with key on and grre with white stripe from the fan switch or grounded somewhere to always have the fan on. Was that wire connected, or just hanging loose like that?
Glowsock
Jul 24, 2025 03:15 PM
RazorN8
Jan 7, 2022 11:44 AM
mustangman65_79
Apr 14, 2017 05:37 PM
Bryan F
Aug 18, 2015 02:28 PM
Kaweh
Aug 9, 2015 02:54 PM
