new 92 rs need help
Old Jul 16, 2012 | 12:36 PM
92rsteal's Avatar
Car: 92 rs
Engine: 3.1l v6
Transmission: auto
new 92 rs need help
hey just bought a 92rs v6 the gauges partial work the speedo isn't reading the tac sticks idt the gas is reading it looks as if the temp is reading n so is the oil how do i test each one and trouble shoot also what switch should be on the left hand side under the **** for the lights
Old Jul 16, 2012 | 02:25 PM
SKELITOR117's Avatar
Car: 1992 Camaro RS
Engine: 5.0 TBI L03 V8
Transmission: Rebuilt 700R4 W/ Corvette shift kit
Axle/Gears: 2:73 open
Re: new 92 rs need help
Welcome to TGO. First off, you need to work on your punctuation. Members here HATE half assed writing. It is very hard to read and understand what you say when you write a whole paragraph as one sentence. If your gauges are screwy, there is no one right answer, as each gauge can have its own problem. One might have a problem with a sensor, while another is actually a broken gauge. I'm having a problem with reading what you wrote, so try to re-write it as proper and as descriptive as you can so that I and other members can properly help you and give you accurate and appropriate advice.
Old Jul 16, 2012 | 02:43 PM
Phenom-1's Avatar
Car: 1992 Chevrolet Camaro Z28
Engine: 5.7 TPI
Transmission: 700R4 Overdrive Automatic
Axle/Gears: 3.23:1 Positraction
The RS shouldn't have a switch under the **** for the lights, unless someone wired in fog lamps then you'd need a switch for them but The Z28 is the only one that came with Fog lamps from the factory.
