MSD 6AL Tach fix
Old Aug 1, 2012 | 12:23 PM
Igorealfast's Avatar
Car: 1988 Gta
Engine: 383
Axle/Gears: Stock
MSD 6AL Tach fix
Just installed a digital 6AL on my 88 GTA. At 3000 rpm or WOT the tach went to zero. Here's the fix. Out of the MSD harness is a grey wire dedicated tach signal wire. There is a white tach wire in the factory harness that comes out off of the coil. There is a factory grey connector that attaches the white coil tach wire to white wire in the harness. Disconnect these two, and attach the grey MSD wire to the white wire that goes into the harness. Your tach will work fine. You will not need the 8910 tach adaptor. TA DA!
Old Aug 1, 2012 | 03:23 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Re: MSD 6AL Tach fix
That's how the MSD installation instructions say to do it.
Old Aug 1, 2012 | 03:28 PM
Car: 1988 Gta
Engine: 383
Axle/Gears: Stock
That's great but it wasn't in my instructions which is weird. Called MSD and worked it out with one of their techs.
Old Aug 1, 2012 | 04:45 PM
winger67's Avatar
It's probably been a dozen years ago but yeah, MSD sold me the tach adapter to try and fix the issue. I need to find the tach lead from the MSD 6AL.
Old Jul 17, 2014 | 02:27 PM
BWilcox's Avatar
Car: 87 IROC
Engine: 420 EFI
Transmission: TKO500
Axle/Gears: Moser 9" 3:50
Hi Guys,
I am getting ready to install a Digital 6A in my car (87 IROC).
Any updates on the issue?
I talked to MSD Tech support, they indicated that the 6201 should be connected per the harness that was developed for the dual connector coil.
Is this correct?
Best Regards,
Bruce
Old Jul 17, 2014 | 02:46 PM
midias's Avatar
Car: 1984 Trans Am L69
Axle/Gears: 3.42 10 Bolt Posi
Might not help 100% but this is how I wired mine
Hotrodboba400
Dec 10, 2019 07:07 PM
codeysabatini
Nov 10, 2015 04:07 PM
86CamaroDan
Sep 29, 2015 10:08 PM
TrevinE
Sep 14, 2015 03:20 PM
Hotrodboba400
Sep 2, 2015 07:28 PM
