Camaro blinker/dash light issue
Old Aug 21, 2012 | 12:39 AM
djeremy75's Avatar
Hey guys, I just got a camaro, and the right side blinkers work perfectly, but the whole time my headlights are on, the left blinker light on the dash stays on, but when I try to turn on the left blinkers, it stays that way and the only one that works is the marker. Any info on this?
Old Aug 21, 2012 | 02:07 AM
BLKIROCZ87's Avatar
Car: 87 Black Iroc-Z
Engine: 305-LG4/ Soon to be ?
Transmission: TH-350/ soon to be ?
Axle/Gears: 3.73 POSI - Auburn -
Re: Camaro blinker/dash light issue
Check your bulbs 1st then check turn signal "Flasher" relay.. one of those likely
Old Aug 21, 2012 | 09:24 AM
BigBadLou's Avatar
Car: '91 Z28 convertible
Engine: TPI
Axle/Gears: 3.27 posi disc
Welcome to the club, Jeremy.
Based on the information you provided, I suspect your left front park lamp / turn signal. If it has a bad ground or the bulb is gone, it will manifest itself by lighting up the turn signal indicator on the dash.
Do not bother with any relays since our vehicles do not use relays in the turn signal circuit.
And the flasher seems ok because it works fine for the right side blinkers.
Let us know what you find.
Lou
Old Aug 21, 2012 | 05:00 PM
Edwardgp's Avatar
Car: 1983 BB 1995 Z28 Camaro's
Engine: 454-350
Transmission: TH350-4l60e
Axle/Gears: 373 posi-Stock
Welcome, and my vote is for the bad ground. Have had that issue before.
Old Aug 26, 2012 | 09:19 PM
djeremy75's Avatar
If anyone was wondering, it was just a bad ground (as stated, love you guys) in the front left blnker. It had rusted and broke the little metal piece in the socket. I fixed it and every single light works great now. These cars must be sensitive
Old Aug 29, 2012 | 04:26 PM
87rattler's Avatar
Car: 87 Iroc-Z28
Thanks for posting the solution...too many threads without closure.
Old Aug 29, 2012 | 05:13 PM
Edwardgp's Avatar
Engine: 454-350
Right on.
Frozer!!!
Jan 19, 2024 04:55 PM
Vintageracer
Jan 10, 2020 05:33 PM
TheJoeY88
Dec 31, 2016 07:30 PM
Jae992
Aug 27, 2015 09:07 AM
Omega
Aug 10, 2015 12:46 PM
