where do they go?
Old Aug 28, 2012 | 08:39 PM
dragsta's Avatar
Car: 86 WS6 5sp TA
Transmission: 5sp
Axle/Gears: posi
where do they go?
ok, i decided to start working on "the beast" again and here's some things i found under the hood that were sheet-rigged by a MORON. the fan was unplugged and i THINK i got it back in the right spot. the AC is unplugged and sundry other things.... here are some pics.
Attached Thumbnails where do they go?-open-wiring-harness.jpg   where do they go?-loose-red-wire.jpg   where do they go?-loose-black-wire.jpg
Old Aug 29, 2012 | 10:59 PM
vetteoz's Avatar
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
Re: where do they go?
1.plugs into a weatherpak relay , fuel / fan / ???
2.? Need to know wire colors to identify what that is
3.Is a power feed to somewhere from the junction terminal, look for a cut red wire hanging out of the harness somewhere .
Maybe in that mess that is pic #2
Old Aug 30, 2012 | 01:56 AM
Z28ricer's Avatar
Car: 93 240SX
Engine: LQ9
Axle/Gears: 3.54 R200 IRS
First looks like your fan relay connector.
Second one looks like a fusible link has blown, could be the one feeding the fan relay connector.
Last one not sure without a shot showing where its actually at but I think it might be the other half of where the fusible link got popped ?
Old Aug 30, 2012 | 08:01 AM
dragsta's Avatar
Car: 86 WS6 5sp TA
Transmission: 5sp
Axle/Gears: posi
thanks, i'll try to get some more definitive pics.... after i get this figured out, i need to hook up the aftermarket gauges.
