87 GTA fuel pump fuse
Old Sep 13, 2012 | 05:21 AM
keester's Avatar
The picture did work the first time. Sorry . We are restoring an 87 GTA as a father/son project. We are trying to figure out a fuel pump problem.
Hoping someone could tell me if the missing fuse is for the fuel pump or something else. I tried pulling a fuse from a different spot and the fuse just fell out of this empty slot like the fuse box is broken. Thanks for the help.
File Type: zip
Old Sep 13, 2012 | 07:19 PM
BigBadLou's Avatar
Car: '91 Z28 convertible
Engine: TPI
Axle/Gears: 3.27 posi disc
Re: 87 GTA fuel pump fuse
There is no fuel pump fuse in the fuse box.
There is a fuel pump and ECM memory fuse near the battery, however. It is in a single-fuse holder bolted to the fender and has a red and orange wires.
Hope this helps.
Lou
Old Sep 13, 2012 | 07:46 PM
keester's Avatar
Thanks Lou, That helps a ton!
Old Sep 13, 2012 | 08:28 PM
BigBadLou's Avatar
Engine: TPI
No problem, glad to help.
If you need diagrams to diagnose your fuel pump problem, here are plenty:
http://www.austinthirdgen.org/index.php?pid=19
If you want a troubleshooting article, here is one:
http://www.austinthirdgen.org/index.php?pid=35
Hope this helps.
Lou
Old Sep 13, 2012 | 09:30 PM
keester's Avatar
Lou,
The fuel pump and ECM memory fuse near the battery was blown. I am going to run up to auto zone in the morning and get some fuses. Thanks again for the help.
Glowsock
Jul 24, 2025 03:15 PM
RazorN8
Jan 7, 2022 11:44 AM
gta90
Sep 15, 2015 04:00 PM
justin57
Aug 20, 2015 07:05 PM
Winchester1094
Aug 18, 2015 10:23 AM
