CFI to Carb help
Old Oct 22, 2012 | 10:27 AM
hxras1's Avatar
Car: "82" CFI, camaro, "05" vette
Engine: Changed to 350, adding carb. setup
Axle/Gears: 410, posi disc
CFI to Carb help
The car is an 82 indy pace car, put in a 350, and now want to replace the CFI with a carb. I've got the CFI stuff off the car, and the 4bbl intake installed, carb is still in the box. The big question is, all the computer stuff can go, right? The ECM, the harness, ect...? I believe I need to replace the HEI with a non-computer controlled one?? I pulled the whole harness out of the engine compartment, clear back to ECM, now should I buy a different harness, or what should I do to get the thing rewired? It has a 700r4 tranny, how do I wire that up so the converter will lock up??? Many questions, could really use some help.
Thank you in advance!!
Old Oct 22, 2012 | 10:51 AM
johnf123's Avatar
Car: 1992 RS vert
Engine: forged 383
Transmission: a busted one for now ;)
Axle/Gears: 4th gen 3.73
Re: CFI to Carb help
im doing same thing, stock 305 tbi to blown 350 carb with 700R4, harness just dangling out of car.
Old Oct 22, 2012 | 11:41 AM
mmadden55's Avatar
Car: 86 Firebird
Engine: 305 SBC
Transmission: 700 R4 TCI
No need to remove the harness, just clip and tape the stuff you don't use. You do need a vaccum advance HEI
Old Oct 22, 2012 | 01:04 PM
johnf123's Avatar
Car: 1992 RS vert
Engine: forged 383
alright, is there a special distributor for a double pumper holley 750, or do i use a vacuum advance and cap the lines?
Old Oct 22, 2012 | 01:13 PM
hxras1's Avatar
Thanks, that's a start! Will the ECM be doing anything or can I remove it altogether? Just wondering if the 700r4 lockup is tied to that? As far as the in tank fuel pump, do I need to do something there, regulator, different pump????
Old Oct 22, 2012 | 01:16 PM
johnf123's Avatar
Car: 1992 RS vert
Engine: forged 383
you can keep the stock pump, but youl need a fuel pressure regulator. there is a tech article on the site that is step by step for swapping from EFI to carb
RedLeader289
May 28, 2019 01:47 PM
mcfastestZ28
Oct 1, 2015 11:23 AM
IROC ZELLER
Sep 29, 2015 03:00 PM
efiguy
Sep 27, 2015 01:30 PM
