no spark after heater core replacement
Old Nov 6, 2012 | 07:49 PM
eighty-eight's Avatar
I have an 88 Trans Am, 305 TPI... have the heater core bypassed and today replaced the heater core ...the dash was partially removed/reinstalled and ignition coil was also removed and reinstalled to access the hoses on the firewall. Now the car is not getting any spark. Help!!
Is there something I could have missed in reassembling the car?
There is a plug on the driver's side under the dash, with 5 wires... black, light gray, purple, tan & white, and a dark tan (?) there is also a ground with this plug's wiring...now I can't figure out where this plug is supposed to go!!! and if it could have something to do with the car not getting spark? The car has a digital dash in case that is relevant to this plug.
Any help would be appreciated!
Old Nov 8, 2012 | 12:53 PM
BigBadLou's Avatar
Car: '91 Z28 convertible
Engine: TPI
Axle/Gears: 3.27 posi disc
Re: no spark after heater core replacement
Have you checked that both plugs on the distributor are connected? Same for the coil.
Old Nov 15, 2012 | 01:49 PM
Yes they are all connected. Tested the coil and it tested slightly out of range so replaced it today and still nothing. Back to the drawing board...
Old Nov 15, 2012 | 02:35 PM
BigBadLou's Avatar
Engine: TPI
Power at the pink wire on the coil? (with ignition on)
Unplug the 1-wire connector by the blower motor (the "timing connector"). That will isolate the distributor from the ECM. If you still don't get spark, you have a distributor problem.
Old Nov 15, 2012 | 11:48 PM
Thank you! I will check those things this weekend!
Casey Meyers
Mar 2, 2016 10:46 AM
TheExaminer
Aug 26, 2015 04:59 PM
lakeffect2
Aug 23, 2015 08:44 AM
Cheibu70
Interior Parts Wanted
Aug 15, 2015 12:11 PM
Street Lethal
Aug 14, 2015 08:25 PM
