windsheild wipers!!!
Old Nov 14, 2012 | 05:16 PM
mack1985transam's Avatar
Car: 1985 trans am
Engine: 355 vortec built 4 bolt main
Transmission: 700r4 w/ shift kit b&m console mega
Axle/Gears: 3.08
Here is the skinny. I have a 1985 Trans am. I am having wiper problems. The wipers only work on high and do not park. I have replaced the wiper motor, wiper pulse board, wiper switch, multifunctional arm and also the fuse is good. I have replaced everything.
Old Nov 15, 2012 | 04:38 AM
Ozz1967's Avatar
Car: 1984 Trans Am
Engine: LS1383 in work
Transmission: Magnum F - to be installed
Re: windsheild wipers!!!
You've eliminated teh switch, the motor, and the pulse board. The motor and board should have fixed the issue, but it looks like you'll need to start digging ito the wiring, unless you got a bad board/motor.
Old Jul 13, 2013 | 07:51 PM
pete0013's Avatar
Car: 86 iroc
Engine: 383 ci
Transmission: 700r4 Kevlar kit, non-lockup
Axle/Gears: 3.42 posi
I have a problem with my wipers also, they come on and will cycle through all the settings but will not park or turn off while the car is on, the only way to turn them off is by shutting the car off or unplugging the wiper motor, I believe it is in the column, also the lever keeps falling out
Hal87
Exterior Parts Wanted
Nov 8, 2015 03:40 PM
Hal87
Sep 26, 2015 09:26 PM
adelane
Sep 9, 2015 08:51 PM
