Cruise control won't work...
Old Nov 27, 2012 | 09:06 PM
Ashton89iroc's Avatar
Car: 1987 IROC-Z
Engine: Vortec 350 crate #12530282
Transmission: 700-r4 Auto
my cruise control went out in my 89 iroc. Im not sure if i don't have something hooked up correctly or what. it used to work, but over time i had to push the button multiple times for it to engage and finally it just quit working....any ideas? sorry if that isn't enough info to work off of
Old Dec 3, 2012 | 05:20 PM
NINÅ's Avatar
Engine: ► 400 KUBES ◄
Transmission: 765R4
Axle/Gears: EATON POSI 4.56
Cruise Nite
The fact you have to press it multiple times is consistent with a bad switch, or a bad connection.
Using a voltmeter or test light
(the type for testing for voltage, not a continuity tester) probe the gray wire at the Cruise Module located behind the right side of the dash IP.
When you switch the Cruise to ON, is there power there?
Then probe the
gray wire with a black stripe.
Happy Racing!
He Must Have Been Be Cheating - Because I Was And He Almost Beat Me.
Old Dec 3, 2012 | 05:39 PM
Car: 1987 IROC-Z
Re: Cruise control won't work...
sweet, ill get a test light and get right on that. ill tell you what i find, thanks a lot!
Hotrodboba400
Dec 10, 2019 07:07 PM
Nick McCardle
Sep 10, 2015 08:36 PM
rsrookie
Sep 5, 2015 07:08 PM
Hotrodboba400
Sep 2, 2015 07:28 PM
