computer upgrade
Old Nov 28, 2012 | 04:04 PM
TNT garage's Avatar
computer upgrade
Hi Guys. I have a 82 crossfire that is mostly restored. It runs well but I have come to the conclusion that the computer need to be upgraded. Can anyone steer me in the correct direction?
Old Nov 29, 2012 | 05:19 PM
TNT garage's Avatar
Re: computer upgrade
I understand that with a conversion harness a 92 computer will solve my issues. Any idea where to get one??
Old Nov 30, 2012 | 12:49 AM
vetteoz's Avatar
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
Originally Posted by TNT garage
a 92 computer will solve my issues.?
You taking about a ECM from a later TBI car or truck?
http://www.technovelocity.com/chevyh...m/8746ecm.html
Old Nov 30, 2012 | 10:49 AM
TNT garage's Avatar
Yes. I uesd to have a site that built these but they no longer do. I haven't had any luck finding one.
Old Nov 30, 2012 | 03:53 PM
TNT garage's Avatar
Do you have a link that puts me in touch with these guys? I can't find them. What I need is someone to put this together for me built with my peramiters. Thanks
Old Dec 21, 2012 | 02:58 PM
Tom 400 CFI's Avatar
Engine: LT1, L400
Transmission: ZF6, T5
Axle/Gears: 3.45, 3.31
Well old buddy....I'll tell you what; How about I just copy and paste from another thread, where you were SO helpful!...
there are a lot of things a guy can do in the assembly process to free up quite a few poneys.. "these are speed secerets" I'll sell you the secerets but no one has been able to afford them yet.... LOL
There are some things done that I WILL NOT TELL as I get paid to do these things.
a good crew chief don't devuldge his secrets. I do not care if you do not believe me as I have no reason to lie.
So yeah... what your after is easily achievable. I'd sell you the "secret" but you won't be able to afford it.
Old Dec 21, 2012 | 05:08 PM
Tuned Performance's Avatar
Community Influencer
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
email him, I have a old prominator that may work for the conversion. The email on that link is icole@technovelocity.com you can even contact him at the link below.
https://www.facebook.com/iancole2112
Old Dec 22, 2012 | 11:38 AM
82tarecaro's Avatar
Funny stuff.
Old Dec 22, 2012 | 05:11 PM
TNT garage's Avatar
YEP ROFLMAO
Old Dec 25, 2012 | 08:32 AM
KITT1983's Avatar
Car: 1983 Pontiac Trans Am Daytona 500
Engine: Crossfire 305ci V8
Transmission: Jasper 700R4 4 speed Automatic
Axle/Gears: 3.23 limited slip/posi
ebl flash
http://www.crossfireinjection.net/catalog.htm
http://www.dynamicefi.com/EBL_Flash.php
* Crossfire Corvette:
For the EBL Flash ECM to work in a Crossfire car some additional changes are required. This is due to the type of connectors each ECM uses. The Crossfire ECMs use an edge card connector, while the EBL ECMs use the pin style connector.
Basically there are three options:
1) Replace the EFI harness with one from a TBI car/truck with the proper connectors.
2) Cut off the current ECM harness connectors and splice on the pin style connectors.
3) Have a HAM board installed into the EBL ECM. See DCS at http://www.crossfireinjection.net for the HAM board & install.
HAM Board
Item Name: HAM Board (IN STOCK)
Item Price: $130.95
Item SKU: DCS00013
Shipping USPS Flat Rate: $12.50
IN STOCK
Product Description Convert the GM 127747 or 1228746 TBI ECM to be plug and play compatible with the existing stock CFI harness connection. No need to splice your stock ECM wire harness. Just install the HAM module into the new ECM, plug it in and you are ready for laptop tuning. NOTE: Unsoldering and re-soldering procedures are required to the ECM board for installation, additional hardware and software may be required.
seiplentz
Aug 19, 2019 06:02 PM
Fronzizzle
Feb 9, 2017 09:31 AM
apie2546
Sep 20, 2015 01:03 PM
Necron
Brakes
Sep 14, 2015 12:45 PM
david068513
South East Region
Sep 13, 2015 11:24 AM
