Front Right Blinker Fail
Old Dec 1, 2012 | 12:33 AM
ItalianHunk21's Avatar
Car: 1992 Z28 Camaro
Engine: 5.7L V8
Transmission: Automatic
So this is weird, my front right blinker does not work? Any clue as to how or why? When I put the headlights or parking lights on, the side marker light and front signal light stay lite. When I put the blinker on for the right side, just the rear signal light blinks. The left blinker works fine. My question is, does anyone think it's a bad ground?
Here's a few other things...
When I put the blinker on to the right, the right arrow on the dash does not even light up. Also, if I pull the blub out of the right front signal, the side marker light goes out??? It's as if the power to the side marker is controlled by the front right blinker. The blubs are new, the relay for the signal lights is new, the relay for the hazard lights is good, what on earth could it be?
Thank you
1992 Z28 Camaro 5.7L V8
Old Dec 3, 2012 | 08:52 AM
Engine: 5.7L V8
Re: Front Right Blinker Fail
Well if anyone cares, I ended up checking the power to the actual bulb socket. I first put the left blinker (good side) on. I pulled the signal bulb out and checked the contacts. I then put the right blinker on and pulled the bulb out. I checked the contacts to see if power was getting to it. I realized the contacts on the right bulb might be causing a short. So I cut the actual right turn signal off. As soon as I did that, the right side marker light came on, and when I put the right blinker on, the right dash arrow was now lit. I went to Pep boys and bought a turn signal socket, hooked it up and bingo. My right front turn signal works.
Old Dec 3, 2012 | 11:17 AM
afremont's Avatar
Car: 90 IROC
Engine: 5.7 TPI
Transmission: 4L60
Thanks for reporting what the problem was. Glad you got it fixed.
customblackbird
Aug 15, 2021 10:16 PM
Papaginos
Sep 27, 2015 03:29 PM
Jk_Under
Sep 2, 2015 10:59 PM
Bryan F
Aug 27, 2015 07:28 AM
1Aauto
Sponsored Vendors
Aug 26, 2015 02:18 PM
